Configure and install the digital certificate. For digital certificate information, see Digital Certificate Configuration.
Use this procedure to configure the certificate authority (CA) for the syslog server. This command adds a root or intermediate CA certificate to the syslog certificate store.
    enable
    configure terminal
  2. Configure the CA trustpoint:
    syslog certificate ca-common-name WORD<1-45>
  3. Save the configuration.
  4. Optional: Display the installed syslog server CA trustpoint:
    show syslog certificate
  5. Optional: Display CA details:
    show certificate ca [WORD<1-45>]
    The UsedFor field displays SYSLOG.
The following table defines parameters for the syslog certificate ca-common-name and show certificate ca commands.
Variable Value
WORD<1-45> Specifies the Certificate Authority common name.
